Heizung für IN-5907HD
24,99 €
21,00 €
zzgl. MwSt
Protect your camera from the cold and ensure a flawless operation at temperatures below 0 degrees
Winter is coming... and with it the dangers of a sudden malfunction of your INSTAR IP camera.
We've created a simple solution which is not just energy-efficient but also very effective against the freezng cold. With the INSTAR Camera heater for outdoor devices you are going to be perfectly prepared for the winter.
The heater has an built-in temperature sensor which allows your camera to operate at temperatures far below 0 degrees. In order to save energy it will turn itself off once the temperature reaches +10° C.
The installation of the heater can be easily done by the end customer himself. A detailed installation manual will guide the customer through the simple and quick procedure. Cameras can also be ordered with heaters pre-equipped. Simply put the camera and a suitable heater into your cart. Add the Upgrade Service to our order. A small fee will be charged for the installation.
specification
Overall product information
modified working temperature
-20°C to 55°C
Power supply
12V
max. power consumption
3 Watt
Anforderungen & Maße
Kompatibel zu
IN-5907HD, IN-5907HD PoE
Gewicht
g
Maße in cm (H / B / T)
0 / 0 / 0
