Welcome to the US Store
    IN-PoE 4200 - PoE Switch
    Quick Overview
    4-Port Power over Ethernet Switch
    Article No: 100444
    Availability: In stock
    $90.67
    OR
    More Views
    Details
    IN-PoE 4200 PoE Switch
    The IN-PoE 4200 PoE Switch is a Gigabit Switch that can provide 10/100/1000M Ethernet Data and Power over Ethernet cable. As an Ethernet Power Sourcing Equipment (PSE), this switch is a very smart and safe equipment for Wireless APs, IP Cameras and IP based network equipment. Full-Duplex Flow-Control ensures fast and steady data transfer. Compared to other PoE switches in the market, the IN-PoE 4200 is designed to automatically detect and identify whether the connected devices such as IP cameras comply with standard IEEE PoE 802.3af / 802.3at and supply power for them accordingly.
    Important! Our PoE devices transfer power over pin 4 & 5 (+) and 7 & 8 (-). To prevent any possible damages we urge you to check the compatibility of your PoE end-device first.
    Easy Plug & Play Setup
    It can't be more simple and straight-forward. The installation is quickly done by connecting your PoE devices. An external power adaptor and a power cable is included in this package.
    Put an end to power cables
    All four Ethernet ports of the IN-PoE 4200 support Power-over-Ethernet. Use PoE for applications that are far from power outlets or when you want to minimize the clutter of extra cables. A simple Cat 5 RJ45 cable can establish a data connection and supply power at the same time. This makes an external power supply obsolete.
    Power Supply & Port Priority
    Each PoE port has an output of max. 25.5Watt via IEEE802.3af or 30Watt via IEEE802.3at and has a total output of 120W. The Port Priority will protect your devices if the total power consumption of all powered devices are higher than specified. The ports of the IN-PoE 4200 will be sorted by prirority ranking from highest priority (Port 1) to lowest priority (Port 4). The power supply of the lowest priority will be turned off.
    Cable- & Connection Diagnosis
    Network Features
    Uplink Auto MDI / MDI-X
    Ports 1 Uplink Port, 4 Ports (PoE support)
    Total PoE Output 120 Watt
    Transfer Speed 10 / 100 M
    Swtiching Capacity 16Gbps
    Buffer Memory 96Kb
    Operation & Measurements
    Power Supply External 48V DC Power Adaptor
    max. working temperature -5°C to 55°C
    Measurements in cm (H / W / D) 2.5 / 11.8 / 8.9
    Write Your Own Review
    You're reviewing: IN-PoE 4200 - PoE Switch
    How do you rate this product? *
      1 star 2 stars 3 stars 4 stars 5 stars
    Price / Performance
    Use spaces to separate tags. Use single quotes (') for phrases.
