3m connection cable (black)
for IN-9420 2K+ / IN-9820 4K
89,49 zł 75,20 zł
Original 3 m black INSTAR cable with power, LAN, reset, and alarm connections. Compatible with IN-9420 2K+ & IN-9820 4K.
Dostępność:W magazynie
This 3 m black connection cable is the original spare part for INSTAR IP cameras IN-9420 2K+ and IN-9820 4K.
It includes the full set of ports:
  • Power connector for the power adapter
  • LAN port for wired network connection
  • Reset button to restore factory settings
  • Alarm input & output for external sensors or alarms
Durable, weatherproof, and plug-and-play – perfect for replacing damaged cables or keeping as a spare. The black color blends well in dark or outdoor environments.
Napisz własną recenzję
Napisz opinię o produkcie:3m connection cable (black)
Twoja ocena
