169,99 €
142,85 €
TThe IN-PoE 8200 PoE Switch is a Gigabit Switch that can provide 10/100/1000M Ethernet Data and Power over Ethernet cable. As an Ethernet Power Sourcing Equipment (PSE), this switch is a very smart and safe equipment for Wireless APs, IP Cameras and IP based network equipment. Full-Duplex Flow-Control ensures fast and steady data transfer. Compared to other PoE switches in the market, the IN-PoE 8200 is designed to automatically detect and identify whether the connected devices such as IP cameras comply with standard IEEE PoE 802.3af / 802.3at and supply power for them accordingly.
Important! Our PoE devices transfer power over pin 4 & 5 (+) and 7 & 8 (-). To prevent any possible damages we urge you to check the compatibility of your PoE end-device first.
Easy Plug & Play Setup
Put an end to power cables
Power Supply & Port Priority
Cable- & Connection Diagnosis
specification
Network Features
Switch Type
Unmanaged Switch (Plug &Play)
Supported Network Standards
IEEE802.3, IEEE802.3u, IEEE802.3af, IEEE802.3at, IEEE802.3x (Full-duplex flow control)
Uplink
Auto MDI / MDI-X
Ports
2 Uplink Ports, 8 Ports (PoE support)
PoE Output
max. 25.5 Watt (802.3af), max. 30 Watt (802.3at)
Total PoE Output
250 Watt
PoE Output Pins
4 & 5 (+) / 7 & 8 (-)
Transfer Speed
10 / 100 / 1000 M
Swtiching Capacity
16Gbps
Buffer Memory
192Kb
Operation & Measurements
Power supply
100-240V AC, 50/60Hz
max. Betriebstemperatur
-5°C bis 55°C
Maße in cm (H / B / T)
2.9 / 19 / 10.5
