3m connection cable (white)
for IN-9420 2K+ / IN-9820 4K
1 809,61 ₽ 1 520,68 ₽
White 3 m INSTAR connection cable with power, LAN, reset, and alarm terminals. Original spare for IN-9420 2K+ & IN-9820 4K – ideal for indoor use.
Наличие:В наличии
This white 3 m connection cable is an original INSTAR spare part for the IN-9420 2K+ and IN-9820 4K IP camera models.
It offers the following connections:
  • Power input
  • LAN port
  • Reset button
  • Alarm input & output
Perfect for replacing faulty cables or for clean indoor installations. The white color blends well with light-colored walls and ceilings for discreet setups.
Напишите свой собственный отзыв
You're reviewing:3m connection cable (white)
Ваша оценка
