with slightly visible 850nm IR LEDs
79,99 € 67,22 €
Spotlight with Hi-Power IR LEDs
Disponibilita':Disponibile
Power
IN-906 Infrared Spotlight
External infrared spotlight with 6 high powered IR LEDs for a realistic depth of approximatly 13-15 meters with 80 degree illumination angle. For instance, this infrared spotlight is the perfect companion for the model IN-4010 V2. You can also use the IN-906 Spotlight with every other night vision compatible cameras in order to improve the night view. The infrared spotlight can be directly plugged into every power socket and has an automatic sensor which automatically turns the spotlight on and off. As soon as it gets dark the IR LEDs will activate and illuminates the area with invisible infrared light. Please keep in mind that objects in front of the camera will reflect IR light thus increasing the illumination. The more surfaces in the near fascinate of the camera the more you will see.
specifica
Informazioni generali sul prodotto
Angolo di illuminazione 80°
Distanza 13 - 15m
LEDs 6 Hi-Power LEDs
Lunghezza d'onda 850nm
Potenza per LED ~ 1.5 W
Power supply 110-240 V / 50Hz
Altri dettagli
Compatibile con IN-2901, IN-2904, IN-2905 V1, IN-2905 V2, IN-2905 PoE, IN-2907, IN-2908, IN-3001, IN-3003, IN-3005, IN-3010, IN-3010 PoE, IN-3011 PoE, IN-3011, IN-4009, IN-4010, IN-4010 V2, IN-4011, IN-5905HD, IN-5907HD, IN-5907HD PoE, IN-6001HD, IN-6011HD, IN-6012HD, IN-6012HD PoE, IN-6014HD, IN-6014HD PoE, IN-7011HD, IN-7011HD PoE, IN-8003 Full HD PoE, IN-8015 Full HD, IN-8015 Full HD PoE, IN-9008 Full HD, IN-9008 Full HD PoE, IN-9010 Full HD, IN-9020 Full HD, IN-8401 2K+, IN-8403 2K+ PoE, IN-8415 2K+, IN-9408 2K+, IN-9408 2K+ PoE, IN-9420 2K+
Peso 640g
Misure in cm (H / L / P) 11.4 / 8.5 / 8.5
Scrivi la tua recensione
Stai recensendo:IN-906 Hi-Power Infrared Spotlight (black)
