Welcome to the US Store
    IN-Motion 500 (V2)
    Quick Overview
    Weather proof infrared & microwave motion detector
    Article No: 100811
    Availability: In stock
    $59.53
    OR
    More Views
    Details
    What is IN-MOTION 500?
    This product, integrated with the dual-microwave and passive infrared light technology, is the best choice for outdoor intruding detection. The dual microwave and the Passive Infrared detecting areas are overlapped to detect moving objects and determine whether it is a real intruder. It is the perfect companion for INSTAR outdoor and indoor IP cameras for a harsh physical environment. This way a tree which is moving in the wind or light which gets turned on and off will not cause an alarm of your ip camera. The IN-MOTION motion detector will not detect this kind of movment as an alarm which will lower the amount of false alarms enormously.
    How does the microwave sensor work?
    The Microwave sensor detects motion through the principle of Doppler radar, it is similar to a radar speed gun. It sends out microwave pulses and measures the reflection off a moving objects. They cover a larger area than infrared sensors, but are more vulnable to electrical interference. Microwave motion detectors are different than PIR motion detectors in that they are active devices. They transmit energy and look for a frequency (Doppler) shift due to motion in the covered area. The microwave motion detector sends out high radio frequency waves and then detect the level of energy reflected back to the device. If the radio frequency wave hits a moving object, the frequency changes and the motion detector is activated. Microwave motion detectors by themselves would cause frequent false alarms as microwave energy penetrates most building material and will therefore “see” through walls.
    What is PIR?
    Advantages:
    • Dual Microwave and Passive Infrared combined
    • Significant reduction of false alarms of your IP camera
    • Auto temperature compensation
    • Internal logic control to avoid false alarms
    • Very easy Plug n Play Technology. Simply plug it in the power outlet and connect it to your ip camera
    Contents of delivery:
    • 1x IN-MOTION 500
    • 1x 5m signal cable
    • 1x power supply (12V / 1A)
    • 1x wall mount
    • 1x set of dowls and screws
    • 1x installation manual
    ATTENTION! In order to use the IN-MOTION 500 you will need a camera with alarm input!
    Overall product information
    Power supply 62mA @ DC12V
    max. power consumption 125mA / 25VDC
    Relais output Normally Closed (NC) / Normally Open (NO), DC 25V / 100mA
    Working temperature -10° C — +50° C
    Start-up duration 60 seconds (warm-up time up to 10 minutes in temperatures below -10°C!)
    Detection distance 12m x 12m
    Detection angle 110°
    Sensor Dual microwave sensor and passive infared sensor
    Special feature Ceiling- or wallmount
    Requirements & Measurements
    For Model IN-2905 V2, IN-2907, IN-2908, IN-3001, IN-3005, IN-3010, IN-3010 PoE, IN-3011, IN-4009, IN-4010, IN-4011, IN-5905HD, IN-5907HD, IN-5907HD PoE, IN-6011HD, IN-6012HD, IN-6012HD PoE, IN-7011HD, IN-7011HD PoE, IN-8015 Full HD
    Weight 150g
    Measurements in cm (H / W / D) 6.0 / 4.5 / 13.6
    Write Your Own Review
    You're reviewing: IN-Motion 500 (V2)
    How do you rate this product? *
      1 star 2 stars 3 stars 4 stars 5 stars
    Price / Performance
    Use spaces to separate tags. Use single quotes (') for phrases.
