IN-PoE 8120 - PoE Switch
120 Watt / Gigabit / 802.3af/at
109,99 € 92,43 €
Smart and space-saving PoE switch with 8 Gigabit PoE ports and 2 dedicated uplink ports for smooth network integration. Delivers up to 120 W total power for IP cameras, access points, and other PoE-enabled devices. With automatic PoE detection, IEEE 802.3af/at support, and built-in diagnostics.
Disponibilité:En stock
Variante : 8 ports + 2 ports montants
IN-8200 Commutateur Gigabit PoE IN-4200 Commutateur Gigabit PoE
IN-PoE 8120 Gigabit PoE Switch
The IN-PoE 8120 is a compact and energy-conscious 8-port Gigabit PoE switch with two additional uplink ports for seamless integration into larger networks. Each PoE port delivers up to 30 W (IEEE 802.3at), with a combined power budget of 120 W – ideal for smaller installations like IP surveillance or office setups. The switch supports automatic device recognition, plug-and-play installation, and features intelligent power prioritization and built-in diagnostics for a stable and secure network experience.
Quick Deployment
Ready to go in seconds – simply connect your devices and power up using the included adapter. PoE-enabled devices are detected automatically and powered accordingly.
Data & Power via One Cable
With only a single Ethernet cable, the IN-PoE 8120 delivers both data and power – no need for extra power lines. A perfect fit for ceiling-mounted IP cameras, remote access points, or office solutions.
Smart Power Control
Integrated port priority safeguards your network in case the 120 W budget is exceeded – low-priority ports are disabled first, ensuring continued operation for critical devices.
Built-in Cable Diagnostics
Built-in status LEDs quickly identify faulty cables or connection errors – helping you maintain a rock-solid network.
spécification
Fonctionnalités du réseau
Type de switch Switch non administrable (Plug & Play)
Normes de réseau prises en charge IEEE802.3, IEEE802.3u, IEEE802.3af, IEEE802.3at, IEEE802.3x (Contrôle de flux en duplex intégral)
Lien montant Auto MDI / MDI-X
Ports 2 ports d'uplink, 8 ports (prise en charge PoE)
Puissance de sortie PoE max. 15.4 Watt (802.3af), max. 30 watts (802.3at)
Puissance de sortie totale PoE 120 watts
Broches de sortie PoE 4 & 5 (+) / 7 & 8 (-)
Vitesse de transfert 10 / 100 / 1000 Mbit
Capacité de commutation 16Gbps
Mémoire tampon 192Kb
Alimentation & Taille
Alimentation électrique 100-240V AC, 50/60Hz
Température maximale de fonctionnement -5°C à 55°C
Mesures en cm (H / L / P) 4.1 / 19.6 / 13.2
Vous commentez :IN-PoE 8120 - PoE Switch
Votre évaluation
