IN-PoE 4200 - Gigabit PoE Switch
98,99 € 83,18 €
4-Port Power over Ethernet Switch
Disponibilité:En stock
Variante : 4 ports + 2 ports montants
IN-4200 Commutateur Gigabit PoE IN-8200 Commutateur Gigabit PoE
IN-PoE 4200 Gigabit PoE Switch
The IN-PoE 4200 PoE Switch is a Gigabit Switch that can provide 10/100/1000M Ethernet Data and Power over Ethernet cable. As an Ethernet Power Sourcing Equipment (PSE), this switch is a very smart and safe equipment for Wireless APs, IP Cameras and IP based network equipment. Full-Duplex Flow-Control ensures fast and steady data transfer. Compared to other PoE switches in the market, the IN-PoE 4200 is designed to automatically detect and identify whether the connected devices such as IP cameras comply with standard IEEE PoE 802.3af / 802.3at and supply power for them accordingly. Important! Our PoE devices transfer power over pin 4 & 5 (+) and 7 & 8 (-). To prevent any possible damages we urge you to check the compatibility of your PoE end-device first.
Easy Plug & Play Setup
It can't be more simple and straight-forward. The installation is quickly done by connecting your PoE devices. An external power adaptor and a power cable is included in this package.
Put an end to power cables
All four Ethernet ports of the IN-PoE 4200 support Power-over-Ethernet. Use PoE for applications that are far from power outlets or when you want to minimize the clutter of extra cables. A simple Cat 5 RJ45 cable can establish a data connection and supply power at the same time. This makes an external power supply obsolete.
Power Supply & Port Priority
Each PoE port has an output of max. 25.5Watt via IEEE802.3af or 30Watt via IEEE802.3at and has a total output of 120W. The Port Priority will protect your devices if the total power consumption of all powered devices are higher than specified. The ports of the IN-PoE 4200 will be sorted by prirority ranking from highest priority (Port 1) to lowest priority (Port 4). The power supply of the lowest priority will be turned off.
Cable- & Connection Diagnosis
Spare Parts
4m cable with connectors for IN-5907HD and IN-7011HD series
spécification
Fonctionnalités du réseau
Type de switch Switch non administrable (Plug & Play)
Normes de réseau prises en charge IEEE802.3, IEEE802.3u, IEEE802.3af, IEEE802.3at, IEEE802.3x (Contrôle de flux en duplex intégral)
Lien montant Auto MDI / MDI-X
Ports 2 ports d'uplink, 4 ports (prise en charge PoE)
Puissance de sortie PoE max. 25.5 watts (802.3af), max. 30 watts (802.3at)
Puissance de sortie totale PoE 120 watts
Broches de sortie PoE 4 & 5 (+) / 7 & 8 (-)
Vitesse de transfert 10 / 100 / 1000 Mbit
Capacité de commutation 16Gbps
Mémoire tampon 96Kb
Alimentation & Taille
Alimentation électrique External 48V DC Power Adaptor
Température maximale de fonctionnement -5°C à 55°C
Mesures en cm (H / L / P) 2.7 / 11.8 / 9.5
Vous commentez :IN-PoE 4200 - Gigabit PoE Switch
