IN-905 V2 Infrared Spotlight
84,99 € 71,42 €
External Infrared Spotlight
Disponibilité:En rupture de stock
External infrared spotlight with 60 strong IR LEDs for a realistic depth of approximatly 20-25 Metern with 60 degree illumination angle. For instance, this infrared spotlight is the perfect companion for the model IN-4010. You can also use the IN-905 Spotlight with every other cameras in order to flood the captured area with more infrared light. The infrared spotlight can be directly plugged into every power socket and has an automatic sensor which automatically turns the spotlight on and off. As soon as it gets dark the IR LEDs will activate and illuminates the area with invisible infrared light. The power usage of the spotlight is about 6-10 Watts depending on how dark the surrounding is. Please keep in mind that objects in front of the camera will reflect IR light thus increasing the illumination. The more objects you have in front of the camera the more you will see.
spécification
Informations générales sur le produit
Angle d'illumination 60°
Distance 20 - 25m
LEDs 60
Longueur d'onde 850nm
Puissance par LED 0.2 W
Alimentation électrique 110-230 V / 50Hz
Fonctionnalité spéciale Éclairage supplémentaire
Autres détails
Compatible avec IN-2901, IN-2904, IN-2905 V1, IN-2905 V2, IN-2905 PoE, IN-2907, IN-2908, IN-3001, IN-3003, IN-3005, IN-3010, IN-3010 PoE, IN-3011 PoE, IN-3011, IN-4009, IN-4010, IN-4010 V2, IN-4011, IN-5905HD, IN-5907HD, IN-5907HD PoE, IN-6001HD, IN-6011HD, IN-6012HD, IN-6012HD PoE, IN-6014HD, IN-6014HD PoE, IN-7011HD, IN-7011HD PoE, IN-8003 Full HD PoE, IN-8015 Full HD, IN-8015 Full HD PoE, IN-9008 Full HD, IN-9008 Full HD PoE, IN-9010 Full HD, IN-9020 Full HD
Poids 400g
Mesures en cm (H / L / P) 17 / 15.5 / 12
Vous commentez :IN-905 V2 Infrared Spotlight
