IN-PoE1030 PoE Injector black
39,99 € 33,61 €
The INSTAR IN-PoE 1030 PoE Injector is a reliable and efficient device designed to simplify the power supply of your network devices. With the ability to combine both the network signal and power into a single Ethernet cable, it eliminates the need for additional power cables, making installations cleaner and more organized. The IN-PoE 1030 supports the IEEE 802.3af/at standard, ensuring compatibility with a wide range of PoE-enabled devices such as IP cameras, wireless access points, and VoIP phones. It offers a high data transfer rate of up to 1000Mbps, ensuring fast and stable network connectivity. With its compact design and easy installation, the INSTAR IN-PoE 1030 PoE Injector is an ideal solution for powering and connecting your PoE devices in a convenient and efficient manner.
Disponibilidad:Disponible
IN-PoE1030
IN-PoE1000 PoE Injector black
What is a PoE Injector?
In order to operate your INSTAR Camera with less cables as possible the IN-PoE1030 will combine the network signal and the power into one "single" network cable. Your network devices (such as your cameras) need to support PoE (Power over Ethernet). The network signal can be transmitted with up to 1000MBits while the injector operates with 48V and 30 Watt tops. With the IN-PoE1030 you are always on the save side. The PoE Injector meets the IEEE 802.3at standard and automatically detects if your end device supports PoE and turns it off in case your device is not supported. This way your devices will not be damaged.
Advantages
Super fast data transfer thanks to 1000MBit It can handle devices with up to 30 Watt. Most injectors only support 15,6 Watt Thanks to a handy sliding system you can combine several injectors in order to save space Quick and easy installation
Content of delivery
1x IN-PoE1030 (PoE Injector) in black 1x power cable 1x installation guide
especificación
Información general del producto
Input Voltage 100 - 240V
Power output IEEE 802.3at (max. 48V, 30W)
Chipset -
Data transfer rate 1000 MBit
Special feature Combines data and power connection
Otros detalles
Compatible con el modelo de cámara All PoE cameras
Peso 200g
Medidas en cm (A / L / P) 5.3 / 3.3 / 11.9
Escribir Su propia reseña
Estás revisando:IN-PoE1030 PoE Injector black
