IN-PoE 8120 - PoE Switch
120 Watt / Gigabit / 802.3af/at
$121.26 $101.90
Smart and space-saving PoE switch with 8 Gigabit PoE ports and 2 dedicated uplink ports for smooth network integration. Delivers up to 120 W total power for IP cameras, access points, and other PoE-enabled devices. With automatic PoE detection, IEEE 802.3af/at support, and built-in diagnostics.
Availability:In stock
IN-8120 Gigabit PoE Switch IN-4200 Gigabit PoE Switch
IN-PoE 8120 Gigabit PoE Switch
The IN-PoE 8120 is a compact and energy-conscious 8-port Gigabit PoE switch with two additional uplink ports for seamless integration into larger networks. Each PoE port delivers up to 30 W (IEEE 802.3at), with a combined power budget of 120 W – ideal for smaller installations like IP surveillance or office setups. The switch supports automatic device recognition, plug-and-play installation, and features intelligent power prioritization and built-in diagnostics for a stable and secure network experience.
Quick Deployment
Ready to go in seconds – simply connect your devices and power up using the included adapter. PoE-enabled devices are detected automatically and powered accordingly.
Data & Power via One Cable
With only a single Ethernet cable, the IN-PoE 8120 delivers both data and power – no need for extra power lines. A perfect fit for ceiling-mounted IP cameras, remote access points, or office solutions.
Smart Power Control
Integrated port priority safeguards your network in case the 120 W budget is exceeded – low-priority ports are disabled first, ensuring continued operation for critical devices.
Built-in Cable Diagnostics
Built-in status LEDs quickly identify faulty cables or connection errors – helping you maintain a rock-solid network.
specification
Network Features
Uplink Auto MDI / MDI-X
Ports 2 uplink ports, 8 ports (PoE support)
PoE Output max. 15.4 Watt (802.3af), max. 30 watts (802.3at)
Total PoE Output 120 watts
Swtiching Capacity 16Gbps
Buffer Memory 192Kb
Power Supply & Size
Max. operating temperature -5°C to 55°C
Measurements in cm (H / W / D) 4.1 / 19.6 / 13.2
Write Your Own Review
You're reviewing:IN-PoE 8120 - PoE Switch
Your Rating
