IN-PoE 4065 - PoE Switch
$66.14 $55.58
Availability:In stock
Compact and Efficient
Power for 4 PoE Devices
Smart Power Allocation
Status Monitoring
specification
Network Features
Uplink Auto MDI / MDI-X
Ports 2 uplink ports, 4 ports (PoE support)
PoE Output max. 15.4 Watt (802.3af), max. 30 watts (802.3at)
Total PoE Output 65 Watt
Swtiching Capacity 16Gbps
Buffer Memory 192Kb
Power Supply & Size
Max. operating temperature -5°C to 55°C
Measurements in cm (H / W / D) 4.1 / 14.3 / 11.8
Write Your Own Review
You're reviewing:IN-PoE 4065 - PoE Switch
Your Rating
