IN-PoE 4200 - PoE Switch
120 Watt / Gigabit / 802.3af/at
$99.21 $83.37
Compact and reliable PoE switch featuring 4 Gigabit PoE ports and 2 uplink ports for seamless integration into any IP network. Supports IEEE 802.3af/at with up to 30W per port and a total power budget of 120W – perfect for powering IP cameras, Wi-Fi access points, or other PoE-enabled devices.
Availability:In stock
IN-4200 Gigabit PoE Switch IN-8200 Gigabit PoE Switch
IN-PoE 4200 Gigabit PoE Switch
The IN-PoE 4200 PoE Switch is a Gigabit Switch that can provide 10/100/1000M Ethernet Data and Power over Ethernet cable. As an Ethernet Power Sourcing Equipment (PSE), this switch is a very smart and safe equipment for Wireless APs, IP Cameras and IP based network equipment. Full-Duplex Flow-Control ensures fast and steady data transfer. Compared to other PoE switches in the market, the IN-PoE 4200 is designed to automatically detect and identify whether the connected devices such as IP cameras comply with standard IEEE PoE 802.3af / 802.3at and supply power for them accordingly. Important! Our PoE devices transfer power over pin 4 & 5 (+) and 7 & 8 (-). To prevent any possible damages we urge you to check the compatibility of your PoE end-device first.
Easy Plug & Play Setup
It can't be more simple and straight-forward. The installation is quickly done by connecting your PoE devices. An external power adaptor and a power cable is included in this package.
Put an end to power cables
All four Ethernet ports of the IN-PoE 4200 support Power-over-Ethernet. Use PoE for applications that are far from power outlets or when you want to minimize the clutter of extra cables. A simple Cat 5 RJ45 cable can establish a data connection and supply power at the same time. This makes an external power supply obsolete.
Power Supply & Port Priority
Each PoE port has an output of max. 25.5Watt via IEEE802.3af or 30Watt via IEEE802.3at and has a total output of 120W. The Port Priority will protect your devices if the total power consumption of all powered devices are higher than specified. The ports of the IN-PoE 4200 will be sorted by prirority ranking from highest priority (Port 1) to lowest priority (Port 4). The power supply of the lowest priority will be turned off.
Cable- & Connection Diagnosis
Spare Parts
4m cable with connectors for IN-5907HD and IN-7011HD series
specification
Network Features
Uplink Auto MDI / MDI-X
Ports 2 uplink ports, 4 ports (PoE support)
PoE Output max. 15.4 Watt (802.3af), max. 30 watts (802.3at)
Total PoE Output 120 watts
Swtiching Capacity 16Gbps
Buffer Memory 96Kb
Power Supply & Size
Power supply External 48V DC Power Adaptor
Max. operating temperature -5°C to 55°C
Measurements in cm (H / W / D) 2.7 / 11.8 / 9.5
Write Your Own Review
You're reviewing:IN-PoE 4200 - PoE Switch
Your Rating
