IN-Motion 300 black
$54.98 $46.21
N-MOTION is a passive (PIR) motion detector. This sensor is the perfect extension for your ip camera in order to minimize false alarms.
Availability:In stock
color:black
IN-Motion 300 black IN-Motion 300 white
What is IN-MOTION 300?
What is PIR?
Advantages:
Significant reduction of false alarms of your IP camera Very easy Plug n Play Technology. Simply plug it in the power outlet and connect it to your ip camera Accurate detection of humans thanks to high quality infrared sensors
Contents of delivery:
1x IN-MOTION 300 1x 4m signal cable 1x power supply (12V / 3A) with 3m cable 1x set of dowls and screws 1x installation manual
Attention
Write Your Own Review
You're reviewing:IN-Motion 300 black
Your Rating
