IN-9420 2K+ white
2 pieces - LAN / PoE / WiFi Version
$639.43 $537.34
Availability:In stock
Color: white
IN-9420 2K+ white IN-9420 2K+ black
IN-9420 2K+ Camera
Wide Angle
Approx. 30-120º Viewing Angle
6 IR and White Light LEDs
350° Pan 100° Tilt
AI-based Object Detection
Heat-sensitive Motion Sensor
Weather Protection
IP66 Weatherproof
PUSH Notification
to Your Phone
Integrate the IP Camera
Directly into the Home App
Native Smart Home
Support with MQTT
Mobile Apps
Free Apps for
Your Smartphone
Encrypted DDNS Access,
E-Mail & FTP Transfer
and Guest Accounts
Software-based Detection
Audio Surveillance
Integrated Noise Detection
Video Recordings
Storage of Alarm Videos
on Internal SD Card
Alarm Schedule
Alarm Activation According
to Schedule
Alarm I/O
For External Sensors &
Alarm Systems
Alarm Signal
Alarm Siren When an
Alarm is Triggered
DS-Lite Internet Connections
Microphone Included
Speaker
Integrated Speaker
Black Out Areas You
Must Not Record
Up to 4 Customizable
Motion Detection Areas
FTP Upload to External
Storage (NAS / Router)
E-Mail Alarm Notification
Alarm Lead Time
Alarm Recordings
With 3-10s Lead Time
Web User Interface for
Support for SDHC
Up to 256GB
Store Your Alarm Videos
In Our Cloud Platform
2K+ Video Resolution
The new Sony STARVIS CMOS sensor provides double the resolution of the sensor in a 1080p (FullHD) camera model. Thanks to the additional 2 million pixels, you can also see distant objects in all detail.
Outdoor cameras with 2K video resolution
Comforting Sense of Security
Avoid false alarms by linking software-based motion detection with the integrated body heat sensor (Passive Infrared, PIR). This way, you only receive alerts when something has actually happened.
Avoid false alarms by an additionally built-in PIR heat sensor
350° Pan & 100° Tilt
  • Two-Way Talk
    Speaker
    Built-in Speaker
  • PTZ & Preset Positions
Keep Your
Alarm Videos Safe
Your camera can store alarm recordings on the internal SD card, upload them to a private FTP(S) or SFTP server, or transfer them to the optional INSTAR Cloud to keep the files secure. Each alarm event can trigger a short alarm recording that will be automatically uploaded to your INSTAR Cloud account – safe, on German servers, and accessible only to you!
More info about the Cloud
SD Card Icon
SD Card
max. up to 256 GB
FTP Upload Icon
e.g. Your NAS / Router
Cloud Storage Icon
Automatic upload to the Cloud (optional)
Banner for INSTAR Cloud
A camera that speaks "Smart Home"
Smart home systems are very diverse. But what they have in common is the language they speak. Wireless sensors connect to your smart home gateway via standards like Zigbee, Z-Wave, or EnOcean. While wired devices mostly communicate via the MQTT protocol. Use your camera as an MQTT hub in your home network and give your smart home 100% control over all camera functions. By providing this standard conformity, you can indirectly link any sensor in your house to your camera.
See more about MQTT
Smart living with INSTAR
All smart home systems build on a component commonly referred to as a "gateway." This gateway - a black box that you connect to your router or a cloud platform like IFTTT - contains the logic that controls your home automation. It also has interfaces through which sensors and actuators can be connected and configured according to your needs. INSTAR cameras can be added to a large number of systems via their HTTP and MQTT interfaces. Everything connected to your gateway is indirectly connected to your INSTAR camera - Amazon Alexa, Phillips Hue, Google Assistant, Cortana.
Show more Smart Home content
INSTAR Cloud works with Amazon Alexa
INSTAR Cloud Skill - ask Alexa to play alarm videos on your Echo Spot or Echo Show. Let Alexa show you only videos where the INSTAR Cloud algorithm has detected cars or people. Activate email notification and object recognition with a convenient voice command.
Learn more about the INSTAR Alexa Skill
Easy Installation
Scope of Delivery
Manual
Wall Mount
Ceiling Mount
Screws & Anchors
Power Adapter
Lens & Sensor
CMOS Sensor 1/2.8 inch Sony Starlight Sensor
MegaPixel 4.0MP
Light Sensitivity STARVIS
Lens Mount Custom
Lens 2.7-13.5mm
Viewing Angle approx. 30-120°
Optical Zoom 5x
Video Settings
Video compression (Codec) H265, H264, MJPEG
Min. Resolution 1280x720
Max. Resolution 2560x1440
Framerate 30fps (2K+)
Picture (turn / mirror) 180°, Yes
Communication
LAN connection (RJ45) 10/100 MBit
Integrated PoE Enabled
Integrated Wi-Fi up to 433 Mbit
WiFi Frequency Band 2.4 GHz / 5 GHz
Max. recommended Wi-Fi Distance approx. 8-12m
Detachable Antenna Yes
Wi-Fi Encryption WPA2, WPA3, Enterprise
Encryption Type TKIP, AES
WPS Enabled
Night vision
Infrared Night Vision Enabled
Built-in infrared LEDs 6 High-Power IR LEDs / 6 White Light LEDs
Max. Night Vision Distance 20-30m
Activate Infrared LEDs through PIR Enabled
Works with 940nm LEDs Enabled
Integrated Infrared Cut Filter Enabled
Features
Motion Detection (software-based) Enabled
Integrated PIR Sensor Enabled
AI object detection Enabled
Sound detection Enabled
Alarm I/O In/Output yes / yes
Push Notification Enabled
Alarm Email (with images) Enabled
Upload to the INSTAR Cloud (optional) Enabled
FTPS Encryption Enabled
SFTP Transfer Enabled
Alarm videos / pictures by FTP upload Enabled
Upload per time interval (Photo series) FTP / FTPS / SFTP
Alarm Scheduler Enabled
Video Recording to SD card Enabled
Pre-recording before the alarm Yes - 0-10 seconds
Integrated SD Card 32GB MicroSD (max. up to 1024GB / 1TB)
Snapshot function Enabled
Photo series on SD / FTP Enabled
HTTPS Encryption Enabled
Privacy / Data protection mask Enabled
Multi View (InstarVision App) Enabled
Integrated (free) DDNS address Enabled
Third Party DDNS Providers available DynDNS.com, No-IP.com, Duck DNS, ddnss.de
Integrated P2P UID Enabled
Integrated Microphone Enabled
Integrated Speaker Enabled
Audio Input / Output - / -
Pan & Tilt Control (motor-driven) 355° / 90°
Max. storable Positions 8
Amazon Alexa Enabled
Google (Home) Nest Enabled
IFTTT Enabled
ONVIF Protocol Profile S
MQTT Broker / Client Yes (MQTT v5)
Alarm Server (HTTP(S) Request) Enabled
CGI Interface Yes
User Management Enabled
User Groups Admin, User, Guest, Custom
Password Protection Enabled
Supported Operating Systems (OS) Windows, MacOS, Linux
Supported Web Browsers Microsoft Edge, Mozilla Firefox, Google Chrome, Opera, Safari
Supported Smartphones iPhone, iPad, Android, Windows Phone 8, Blackberry
Other Details
Types of mounting Wall and ceiling mounting
Max. operating temperature -20°C to 55°C
Power Supply Input Voltage 100 - 240V
Length of power supply 3m
Power supply PoE or 12V / 2A
max. power consumption 16 Watt
Mounting thread
Weight 1900g
Measurements in cm (H / W / D) 23 / 15 / 15
Write Your Own Review
You're reviewing:IN-9420 2K+ white
Your Rating
Product FAQ
What are the installation requirements? aa
Everything you need to install the camera and add it to your local network is included in the package. Simply connect the camera to your router via LAN cable or Wi-Fi. Once the connection is established, you can use your smartphone or computer to configure your camera according to your needs. All INSTAR cameras can be used within your network without an internet connection. Only if you access the camera from outside your network, you will need a router with internet connection - no additional mandatory fees or subscriptions are required for using INSTAR cameras.
Do I need a plugin (e.g., Flash) to view the camera's video stream? aa
No, all INSTAR 2K+ models offer the option to view the live video as an HTML5 video stream. You do not need any additional browser plugin to view the video. The HTML5 video can also be transmitted encrypted via HTTPS including audio. Alternatively, the video can also be captured via MJPEG or JPEG stream.
Are there any additional costs after purchasing the camera? aa
INSTAR cameras do not have a mandatory subscription service that would incur additional costs. However, INSTAR offers optional PC software (InstarVision 2 for Windows and MacOS) and cloud storage plans (INSTAR Cloud) for expansion needs.
