PoE Splitter 5V
$22.83 $19.18
Splits up PoE into data and power supply
Availability:In stock
Our PoE splitter can be used to deliver 5V to end devices with no power sockets in close vicinity. It supports IEEE802.3af@15.4W and is compatible with both PoE output standards.
Variant 1: Pin 1 & 2 (+); Pin 3 & 6 (-)
Variant 2: Pin 4 & 5 (+); Pin 7 & 8 (-)
specification
General Product Information
Input Voltage EEE802af @ 15.4W / IEEE802.3at @ 30W
Power output 5V 2A (5.5 x 2.1mm & 3.5 x 1.35mm)
Chipset -
Data transfer rate 10/100 MBit
Special feature Combines data and power connection
Other Details
Compatible with IN-2901, IN-2904, IN-2905 V1, IN-2905 V2, IN-2907, IN-2908, IN-3001, IN-3003, IN-3005, IN-3010, IN-3011, IN-6001HD, IN-6011HD, IN-6014HD, IN-8015 Full HD, IN-8401 2K+
Weight 65 g
Measurements in cm (H / W / D) 2.5 / 3 / 9
Write Your Own Review
You're reviewing:PoE Splitter 5V
Your Rating
